A1932 820-01521 20V 0.07A after liquid damage
it-solve
I got this 820-01521, which had liquid damage—no major corrosion on the board, some around CC788/9 and CC8A1. I can see slight heat dissipation from the T2 security chip.
PPVIN_G3H_P5VG3S - 12.63V
PPBUS_G3H - 12.62V
PP3V3_G3H - 3.25V
PP5V_G3S - 0V - 0.42Vdc
CHGR_PHASE1 - 12.40V
Where shall I start from?
Can you see any liquid sign at audio board, flex and connector?
Do you get all AWAKE and SLPS2R voltages?
it-solve
I am keeping the Audio board disconnected, the board outside of the case.
When the inside case with fan, battery and keyboard connected only - still not turning on
PP3V3_AWAKE - 3.2V
PP1V2_AWAKE - 1.19V
PP1V8_AWAKE - 1.80V
Checking SLPS2R now
"I am keeping the Audio board disconnected"
I said to check for liquid signs.
Leakage from PPBUS_G3H to any T2 data lines from audio side, could already damaged T2; no matters audio board is connected, or not now.
If mentioned voltages are present, machine should be recognized in DFU mode.
If not, very likely bad T2...
it-solve
That makes sense.
Yes, there is heavy liquid on the audio connector board. All SLPS2R voltages are present too.
Last shot try in DFU mode then?
it-solve
Seems that's the case. No key/port combination got the DFU mode detected. Shame on Apple for this crappy design.
Seems they calculated very good this.
Liquid damage puts the machine out of warranty and force people to buy new one.
