A1932
Tizang
Hi Guys,
can you help me. I got an A1932 with the mainboard drawing 20V and 1.5 A. When attached to the power supply it starts charging with 20V and 0,6A and climbs up to 20V and 1.5A and stops there. Keyboard and Trackpad are functioning but it wont start. The 2R7 is getting a little bit hot, when attached to the battery. I already swaped it but no difference.
Thanks in advance.
Any history available?
"Keyboard and Trackpad are functioning"
Do you mean that Caps Lock LED reacts correctly?
Did you check USB activity and external video?
No. I mean i can click on the trackpad and get the device into dfu mode with the keyboard but the light is not functioning. External Video is not functioning.
Its like this. The volltage at the 12,47V is slowly increasing and then stopping at 12,47. Its charging with 20V and 1.8Amps. Really weird fault. IMG_3519 Large.jpegIMG_3520 Medium.jpeg
Many coils you didn't check there.
Anyway as RAM voltage is missing, the board doesn't boot.
Any fault history available?
It is recognized in DFU?
No fault history available. It is recognized in DFU and you can restore it but afterwards it does the same.
I think i found the fault. There was a line to an resistor broken next to the ram module. I jumped the line and it starts now.
