A1989 820-00850 no power
hgoncalves
Hi.
I have an A1989 820-00850 with no power.
It had CB300 and CB308 burnt, and so I've replaced them and UB300 (wich I realize after it was also a bit burnt in the pads) and now I've 3.3V on both.
DBZ500/503 were broken (maybe I've broke them removing the board) and so I've replace them.
PPBUS_G3H = 12.27V w/o battery
PP20V_USBC_TA_VBUS has 0V and 0.181 on diode reading.
PPDCIN_G3H only has 5.150V and 0.518 on diode reading.
FB200 also has 0V and seams ok.
Only have 5V on ampmeter.
Should I replace QB300?
Can you help?
hgoncalves
UPC_TA_R_OSC was the culprit.
Replacing UB300 fixed it.
However, now, with the battery screw in place, the mac wont't power on. Without the screw attached, it powers on normally.
I have already tested it with anknown good battery and I have the same behavior.
Any idea?
What is PPBUS_G3H voltage, w/ and w/o battery connected?
Check resistance over C7020/23 (ohm scale).
Be sure Q7065 isn't shorted D-S.
