A1989 unable to start investigating due to USB C Port fluctuation
Daffy_ED9
Hi Community,
got a A1989 that shows a strange behaviour while powering up.
USB C Port 1 is stable 5 V at 0,170A draw
USB C Port 2 5V with fluctuating draw jumping from 0,47A down to 0,045A and repeating
USB C Port 3 5V with fluctuating draw jumping from 0,47A down to 0,045A and repeating
USB C Port 4 5V with fluctuating draw jumping from 0,47A down to 0,045A and repeating including rebooting of port
With the thermal camera i was able to identify one CD3215 which is roughly 20 degrees warmer then the threee other ones, reading roughly 50 degrees C.
Also I have identified ELC180 chip to be also pulsing when USB is plugged in.
Video below:
Board is perfectly fine, no liquid spill or any visible damage identified so far.
I have not found any advice on an identical behaviour so far, and am looking forward for your advice
Any history available?
Post voltage and diode mode readings on the 4 LDO lines of each CD3215 chip.
Be aware, 1V1 LDO BMC should appear only on the powered port.
Daffy_ED9
Laptop was purchased as broken, so unclear what happened.
First initial readings attached:
UB300
LDO BMC 0
LDOD 1,1 to 3,9 flucuating
LDOA 1,1 to 1,8 fluctuating
PP3V3 UPC TA LDO 3,1 V
U3100
LDO BMC 0
LDOD 1,7 V
LDOA 1,8
PP3V3 UPC TA LDO 3,2 V
U3200
LDO BMC 0
LDOD 1,7 V
LDOA 1,8
UB400
LDO BMC 0
LDOD 1,7V
LDOA 1,7V
PP3V3 UPC TA LDO 3,3 V
Actually I´m measuring a short on CB300 and CB400, C3100 and C3200 PP3V3_G3H_RTC
Can u help me out on where to get the diode measured please?
