A1990 820-01041-07 no power
hgoncalves
Just realize (It wasen't before) that PP1V8_SSD0 is shorted and her C8732 was a bit lose and his pad is gone (probably damaged when replacing the nand). Is C8732 critical?
I can't see anything hot in the thermal cam, even consuming 0.460A with 1V.
PP2V5_NAND_SSD0 has 0.387 in diode reading and seams ok.
Can I increase the voltage to 1.5V or what should I check from here?
With pure short, even 1V should generate very high current; at least 3A, for 0.3 ohm.
Set PSU amp limit to max first...
Then you have more than 0.3 ohm resistance to ground.
Or you lose power on the cables; use thicker ones.
Less than 3W will not cause enough heat to detect culprit with the fingers.
