A1990 820-01041-A no power
hgoncalves
HI,
I have an A1990 820-01041-A no power that has no power.
It only has pulls 5V on 3 USB C ports, and consumes 0.40A on all 3 ports, but on another port the amp metter stays black, and i get 0V on F3001. Shall i replace the U3200?
hgoncalves
After all, not everithing it's OK.
The mac already powers on, but is not charging the battery. Only works on charger.
What shall I check from here?
Try known good battery first.
Is the battery recognized at least?
Be sure the big screw is tight and data cable is properly connected.
Check voltage and diode mode to ground at SCL/SDA lines of battery bus; before and after Q6950.
Be sure SYS_DETECT_L is pulled down; through R6950, or Q6955.
You can check with o-scope for activity on both sides of Q6950.
