A1990 - 820-01041-A - U3000 blown - short on PIN2 USB_SOC_TYPEC_N
samstown
Hello
For data recovery only, does 820-01041-A need U3000 to start ?
U3000 blown, I removed it, pads 6 & 7 gone. I see a short on PIN2 USB_SOC_TYPEC_N. It goes to UE010 on schematic but the board is a little bit different. If I remove UE010 would Mac start ?
Thanks
Board should start without U3000 (USB redriver); hoping the voltage spike didn't pass over UE010 to T2.
samstown
U3000 looks ok, no short on USB_SOC_P/N but Mac doesn't start. It goes up to 0.5 amp and drop to 0.1
there's 4 USB-C.
Top left port USB-C - nothing, USB-C multimeter stay black
Mid left port USB-C - 20V - up to 0.5 amp and drop to 0.1
Top right port USB-C - 20V - up to 0.5 amp and drop to 0.1
Mid left port USB-C - 5V stay at 5V 0.17 amp
Looking at SSD
SNS_P3V3_G3W_SSD0_N Diode mode .431 Voltage 3.36V
SNS_P3V3_G3W_SSD0_P Diode mode .431 Voltage 3.36V
SNS_PPBUS_MAIN_SSD0_P Diode mode .412 Voltage 12.24V
"Top left port USB-C - nothing, USB-C multimeter stay black!
Very likely dead CD3215 chip.
Compare its diode mode readings with other channels; pay atention to CC1/2 lines.
samstown
DB529 is blown. USBC_TA_USB_TOP_ N was shorted. I remove it, now diode mode is .556 (What component are DB ?) Still not booting.
UB300 - USBC_TA_CC2 diode mode = .550
UB400 - USBC_TB_CC1 diode mode = .548
UB400 - USBC_TB_CC2 diode mode = .552
U3100 - USBC_XA_CC1 diode mode = .584
U3100 - USBC_XA_CC1 diode mode = .588
U3200 - USBC_XB_CC1 diode mode = .53
U3200 - USBC_XB_CC2 diode mode = .124
Should I remove U3200 ? Macbook won't boot if one CD3215 is faulty ?
"U3200 - USBC_XB_CC2 diode mode = .124"
Usually points to bad CD3215 chip.
However, check first diode mode at USBC_XB_CC2_CONN; may have luck and just bad DZ3351.
