A1990 (820-01041) - Touchbar no display / touch
I have here an A1990 - Touchbar doesnt work. (no signs of life)
Note: J5100 was corroded - cleaned it and removed the corrosion. (Flexcable was fine)
J5100 power lines:
- PP1V8_SLPS2RSW_DFR: 1.8V
- PP5V_G3S_DFR_FILT: 5.1V
J5110 power lines:
- PP3V3_G3HSW_DFR: 3.3V
Any idea? Is there something i missed?
Note: Sadly I dont have another topcase with a known good TB for testing.
J5100:
- PIN1 "TP_DFR_TOUCH_PANEL_DETECT" : 1.8V
- PIN2 "DFR_LID_OPEN_L" : 1.4V
- PIN18 "DFR_TOUCH_RESET_L" : 0.04V
J5110:
- PIN10 "DFR_DISP_INT" : 0.0V
- PIN12 "DFR_DISP_RESET_L" : 1.8V
(with touchbar and trackpad connected)
Check these levels with another machine with touchbar.
No need to be exact same model; just compare same touchbar lines.
Also check them in diode mode.
Which pins of J5100 have been affected by corrosion?
J5100:
J5110:
Update: I have compared the values (to a known good board / different model) - same behavior.
I also noticed that " PIN18 "DFR_TOUCH_RESET_L" is during boot like 2-3 seconds on 1.8V then it drops down to 0.04V.
So I guess the board is fine? And just the TB dead?
TB is now working.
After reconnecting the flex all (TB, camera and ALS) is working again - what the hell?
Edit:
Sometimes it’s working sometimes not.
Edit2:
ALS and camera is always working - TB is now dark again.
Only lose the touchbar backlight, or touch functions too?
Clean the connectors; be sure to get good contact.
