Got an A1990 820-01814 which is stuck at 5V with no current draw. Occasionally it does switch to 20v and also with no current draw and no power but i havent seen it do that very often!
It was slightly liquid damaged around JB200 and C9080 - i've cleaned up both areas and no issues there, have also run it through the ultrasonic just to catch anything I didn't see.
PPBUS is not shorted to ground and is reading 0.8v when it's stuck at 5v.
PP3V3_G3H is missing and also not shorted to ground.
Following the CD3215 bootup sequence at u3200 I have:
PP20V_USBC_XB_VBUS 5v
PP3V3_UPC_XB_LDO 3.3v
PP1V8_UPC_XB_LDOA 1.8v
PP1V8_UPC_XB_LDOD 1.8v
PP1V1_UPC_XB_LDO_BMC 0.1v
So it seems to be getting stuck at reading the thunderbolt rom. All four ports on the macbook behave the same!
What would the next step at this point be?
