I have A1990 that died randomly during use, customer says image on the screen dissapeared when the device was on.
Board is in pristine condition, never dropped, no dust, zero signs of corrosion anywhere.
Trackpad clicks, its powering on and battery is charging. Both cpu and gpu getting warm.
Detected in DFU always, but neither revive or restore worked.
I see that everything stops at:
<<Started checkpoint id: 0x667 (wait_for_macefi_firmware_update)>>
My uninformed guess - bios chip failure?
When I do restore it stops, here is the log.
(full log attached in zip)
My question is - is it worth investigating or is it most likely dead T2/cpu/gpu?
Thank you
DFU log:
[23:57:26.7694] Started checkpoint id: 0x667 (wait_for_macefi_firmware_update)
[23:57:26.9692] RestoreOS mode device disconnected
[23:57:26.9692] RestoreOS device removed before restored completed
[23:58:27.2089] sock 24: recv(24, 4) failed: Operation timed out
[23:58:27.2090] sock 24: unable to read message size: -1
[23:58:27.2092] Failed to receive message from device, might be connection problem with USB host.
[23:58:27.2092] AMRAuthInstallDeletePersonalizedBundle
[23:58:27.2095] preserved personalized bundle: (null)
[23:58:27.2095] <Restore Device 0xb8a2acc00>: Restore failed (result = 9)
[23:58:27.2095] Can't send dump_console command since device is not in recovery mode
[23:58:27.2095] AMRestorePerformRestoreModeRestoreWithError failed with error: 9
[23:58:27.2095] Finished RestoreOS Restore Phase: Failed
[23:58:27.2095] State Machine Dump, status:ERROR - [state:Recovery remaining-cycles:0] -> [state:RestoreOS remaining-cycles:0 (current state)]
[23:58:27.2097] Changing state from 'Restoring' to 'Error'
[23:58:27.2097] State is now set to error: AMRestorePerformRestoreModeRestoreWithError failed with error: 9
[23:58:27.2158] Restore completed, status: 9
[23:58:27.2158] Elapsed time (in seconds): 118
[23:58:27.2158] Restore Checkpoint Fingerprint: 0667.0000
[23:58:27.2158] Failure Description:
[23:58:27.2158] Depth:0 Code:-1 Error:AMRestorePerformRestoreModeRestoreWithError failed with error: 9
[23:58:27.2158] Depth:1 Code:9 Error:Failed to receive message from device, might be connection problem with USB host. (Communication error, possibly USB disconnection)
Thank you
DFU log:
