A2141 820-001700
madrefoca534
Hello everyone.
I have a MacBook A2141 on my desktop. Here's the story.
The computer wouldn't turn on at first. I discovered a 0 ohm resistor, measuring 0.950 M ohms. R7813. I replaced the faulty resistor, and the computer turned on without any problems. I reassembled and closed it. When I tried to turn it back on, it wouldn't turn on at all. I opened it again, disassembled it, and closed it, and it turned on without any problems. I left it playing videos, lowered the screen, and a few hours later, I opened it again, and it didn't turn on. It hasn't turned on since then. The voltage measurement is 20V at 750-800mA and drops to 100mA. I only have stable voltage on L7660 = 3.3V L7600 = 5.0V L6960/61 = 3.3V
L7813, L7817, L7816, L7814, L7815, and L7811 have the corresponding voltages, except for L7821 and L7822, which are at 0 volts.
The board, without a battery connected, draws 20V at 0.040mA. I don't know if this is normal for this device. Sometimes it reaches 100mA, but then drops to 0, but it always maintains 20V.
I need your guidance, please. Thank you.
madrefoca534
A friend lent me a computer with the same specifications, and it's working.
The battery is good. I mounted the motherboard on my friend's chassis and it turned on without any problems. So far, everything is fine.
My suspicions about the battery are coming true. I'll report on the progress.
madrefoca534
The battery is definitely the problem. I tried it with my friend's chassis battery and nothing bad happened. Everything works perfectly.
I'll replace the battery.
Thanks again for your tremendous help.
