A2141 - 820-01700 Lid Sensor
hgoncalves
Hi.
I have an A2141 820-01700 that with the J4802 lid sensor connected causes the Mac not to turn on.
Already replaced the sensor but same result.
All pins on J4802 seams OK, and their diode readings are normal.
Can you help?
hgoncalves
Hi.
Pin 2 (PP3V3_G3H_RTC_X) was a bit loose, and after resoldering it, everything started to work normaly.
TKS!
