A2141 and replacing mux chip
adrko
Hello
I replaced a mux chip on a A2141,image on external but no image on the MacBook lcd
Is it possible for mux to be bad or badly soldered and have image on external?
Why did you change GMUX?
Any history available.
If liquid damage on video connector, that must be solved first.
BTW, isn't this machine syill in warranty?
Did you check Apple change screen program availability?
adrko
Hello, sorry for not providing context.
It’s a liquid damaged MacBook.
backlight shorted to mux, mux was blown and was shorting one of the power lines supplying it.
Replaced it and the machine is working. It’s a laptop I bought in November, as a repair project.
There were quite a few problems with it.
I struggled with it but I replaced the connector and the receptacle on the logic board.
There was also corrosion on the tcon board, replaced that but I didn’t know if new tcon was working, it arrived from eBay not secured properly and slightly bent. I’m currently thinking about buying whole new lcd assembly and replacing that.
So there’s my question to be sure that I’m doing the right thing at the moment
I also replaced components around touchbar connector and touchbar connector itself.
adrko
I agree, I was just wondering if there’s a possibility of mux chip not working but still having image on external.
I went through the schematics but I wasn’t able to understand if the mux chip is also responsible for providing image to external.
Just trying to make sure that if I spend 600-800$ on a new screen it will work
adrko
Oh I see, thanks man. It might be possible that I haven’t soldered the gmux properly. Is there a way to check for signals with a multimeter to see if the multiplexer is doing what it’s supposed to?
An o-scope can help.
You can also check some signals on it.
Dificil to say something more explicit, as you didn't post your board model until now.
adrko
I forgot, sorry.
820-01700 2019 touchbar 16 inch MacBook Pro 2019 A2141.
I’m not really able to afford an oscilloscope atm, I only have a Uni-t UT61D multimeter.
I really appreciate the help, thank you
You need to discard the LCD assembly.
Put it apart and wait untill get similat machine, with compatible screen.
adrko
I will, thank you.
I think I’ll take a bet and buy a new screen or look for a broken one to test.
Thank you and have a great weekend
