A2159 820-01598-A no power
hgoncalves
I have an A2159 820-01598-A with no power.
It pulls 5V from ampmeter and 0A.
PPBUS_G3H is shorted. It has 0.002 on diode reading.
PPVIN_G3H_P3V3G3HRTC is also shorted with the same readings.
Can I inject voltage there?
How can you ask this after many years?
Check if any coil gives you the same reading as PPBUS_G3H.
If none, then is safe to inject voltage.
hgoncalves
Sorry for so many questions, but I prefer to be sure before doing worse. I'm stiil learning this.
L7210 and L7220 have the same readings.
Low resistance on CPU core may be normal; compare with good board.
CPU can be dead now, but you can try changing U7210.
12.30V because T2 doesn't control it yet.
Do you get 3V3_G3H?
Also check SLPS2R and AWAKE voltages.
If present, try DFU revive.
"CPU can be dead now..."
Remember that.
