A2159 820-01598 no image
hgoncalves
I have an A2159 820-01598 with no image / backlight on internal display, but I have external image.
Already tried with known good display.
Client has droped a bit of coffe on it, and it has a bit of corrosion on L8420, and on U8400 area.
Several test pads under PPVOUT_S0_LCDBKLT_F caps are burnt (gone), and I only have 12V on PPVOUT_S0_LCDBKLT_F (not sure if it should that low).
BKLT_EN_R = 3.288V
BKLT_SDA/SCL = 4.5V
Can you help?
hgoncalves
I've removed U8400 and soldered again, and replaced L8420 with an 47 ohm resistor (0402), but I have the same result.
I think that on the first power on It showed the Apple logo for a sec, but then nothing else. Complete black image.
"replaced L8420 with an 47 ohm resistor"
That is just a coil; why did you replace it with a resistor???
47 ohm is not its resistance for DC current!
You must get 0 ohm reading in ohm scale...
hgoncalves
I've replaced L8420 with a 47 ohm resistor, because I don't have a donor board of the same model, either a coil to replace it, and it was the spec on the schematic (I thought it will do the job).
Can I replace it with a 0 ohm resistor?
As I said, 47 ohm is not its resistance in DC current.
That is the resistance for AC current.
Use a tiny wire instead...
