A2179 - 820-01958 - Heavy Coffee Damage - 20V 0.05A->0A->0.05A Fluctuating PP5V_G3S
it-solve
Merry Xmas, Healthy and Prosperous New Year.
PPBUS_G3H ok
PP5V_G3S - 5V -> 0V -> 5V
T2 heats up and down.
Heavy corrosion around the Tpad/KBD board
Corrosion around: U31/3200, U3060, C6406/6415, R5410 area, U9060, Q7660/80, Q7065, Q7401, R7430
There are no shorts anywhere. U7800 Diode mode seems to match a functioning board
it-solve
I have reflowed the BGAs CD32s/U6400/U6860 which had liquid around. Is there other way to localise why PP5V_g3S is fluctuating without a short?
Or do I need to keep pulling these BGAs out and resoldering them back?
it-solve
Went through majority of the test points mostly match, some doesn't but i dont have them marked as test points on the board view so cant confirm what they are for.
Looking around these corroded ones in C6415,C6406 area.
I do not have any short to the PPBUS_G3H there and chip is not shorting. Only suspicious part seemed to be SPKRAMP_INT_L which still measures 0.46Vdc in diode mode at R6400 test point, which aligns with a functioning board board. However, this trace leads to T2 and I am wondering if trace leads from the test point instead from the R4600 to the T2.
Can you remind me what the _L was in the trace name? Would this line needs to be hold low for normal operation?
The "_L" refers to an active low signal.
An interruption sent from speaker amp to T2 may not be desired.
However, I recommend to compare the signals with good board.
I think we already got mismatch with speaker amp reset from Apple.
it-solve
Active low being low when it needs to communicate (being active) and should not stay low most of the time?
I get on both boards' same readings for these
SPKRAMP_INT_L - 0.46Vdc
SPKRAMP_RESET_L - 0.43Vdc
To compare the signals I will need a scope, I have a signal analyzer but I doubt it will be a fit.
