A2179 820-01958 Not turning on, 20V 0.06A - DFU Restore error 4013
it-solve
Read around that it could be a SSD failure. Anyone come across this?
Gets deceted in Recovery mode, Did Revive and Restore, same error.
Unexpected device state 'Recovery' expected 'RestoreOS' (Probably caused by corruption or panic in the bundle's restored) [com.apple.MobileDevice.MobileRestore – 0xFAD (4013)]
How to push on DFU mode? With bare bore on desk, SOC_FORCE_DFU pad to ground is not triggering it.
Managed to push to DFu mode. System restore goes through Installing system and fails.
Different progress on each attempt, once even show a loading apple logo with slight fan spin attempt and cut off.
This board has no sighs of any liquid or corrosion.
You should try more times.
Once, I got a machine working even when DFU didn't complete.
It never showed an error, just stuck in last step; however, machine started working.
Be sure to have charged battery and good trackpad connected.
YEah battery charged as it stopped pulling charging current, trackpad seems ok with no corrosiopn.
tried about 20 times now, mainly comes with this error:
RestoreOS device removed before restored completed [com.apple.MobileDevice.MobileRestore – 0xFAA (4010)]
Could it be failing SSD loosing its mind?
This is 2019 model and comes with 2x256gb ssd,
I have 2018 A2179 with 2x128GB ssd. Would that be a direct swap or do I need a programmer for the ssd nands?
Could it be NAND issue? Connected without pushing to DFU it comes as Recovery in Apple Configurator. But either ways is not completig restore nor revive.
Looking at the logs its keep repeating this error
ay 5 21:28:10 --- last message repeated 1 time ---
May 5 21:28:13 A2442SG com.apple.configurator.xpc.DeviceService[17601]: failed to get board config from DFU mode device
May 5 21:28:13 A2442SG syslogd[133]: ASL Sender Statistics
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: [PurpleReverseProxy]: May 05 21:28:40 com.apple.configurator.xpc.DeviceService[17601] <Error>: RPSocket.cpp:599(RPSocketReadBuffer): read error on <RPSocket 0x15ae10a30 0x600002b85100: (null) fd fd=15>: Operation timed out
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: [PurpleReverseProxy]: May 05 21:28:40 com.apple.configurator.xpc.DeviceService[17601] <Error>: RPSocket.cpp:640(RPSocketReadDictionary): failed to read length from <RPSocket 0x15ae10a30 0x600002b85100: (null) fd fd=15>
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: [PurpleReverseProxy]: May 05 21:28:40 com.apple.configurator.xpc.DeviceService[17601] <Error>: RPSocket.cpp:223(invoke): No client callback, missing event 8 for socket 0x15ae10a30
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: [PurpleReverseProxy]: May 05 21:28:40 com.apple.configurator.xpc.DeviceService[17601] <Error>: ReverseProxyHost.c:391(RPSocksProxyStart): Device doesn't support new protocol; falling back to old protocol for now
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: sock 16: connecting to <unknown> failed: No route to host (65)
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: sock -1: connecting to [usbmux_5]:1082 failed: Device not configured (6)
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: [PurpleReverseProxy]: May 05 21:28:40 com.apple.configurator.xpc.DeviceService[17601] <Error>: ReverseProxyHost.c:45(RPSocksProxyConnect): failed to connect: Operation not permitted
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: <Restore Device 0x15c80dfd0>: Restore failed (result = 9)
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: Checkpoint data after a restore is NULL.
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: Can't send dump_console command since device is not in recovery mode
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: AMRestorePerformRestoreModeRestoreWithError failed with error: 9
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: State Machine Dump, status:ERROR - [state:DFU remaining-cycles:1] -> [state:Recovery remaining-cycles:1] -> [state:RestoreOS remaining-cycles:0 (current state)]
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: Unexpected state change from 'Restoring' to 'Error' while restoring
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: State is now set to error: RestoreOS device removed before restored completed
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: Device isn't booted but USB is up.
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: Device doesn't have a power assertion to remove
May 5 21:28:40 A2442SG com.apple.configurator.xpc.DeviceService[17601]: Can't stop using resource that nobody was using previously
May 5 21:29:09 A2442SG AMPDeviceDiscoveryAgent[589]: Entered:_AMDFUDeviceDisconnected, libusbrestore-device:0x0x132b0ac80
May 5 21:29:09 A2442SG AMPDeviceDiscoveryAgent[589]: Entered:__thr_AMDFUDeviceDisconnected, libusbrestore-device:0x0x132b0ac80
May 5 21:29:09 A2442SG AMPDeviceDiscoveryAgent[589]: DFU mode device disconnected
May 5 21:29:09 A2442SG com.apple.configurator.xpc.DeviceService[17601]: Entered:_AMDFUDeviceDisconnected, libusbrestore-device:0x0x600001c51760
May 5 21:29:09 A2442SG com.apple.configurator.xpc.DeviceService[17601]: Entered:__thr_AMDFUDeviceDisconnected, libusbrestore-device:0x0x600001c51760
May 5 21:29:09 A2442SG com.apple.configurator.xpc.DeviceService[17601]: DFU mode device disconnected
May 5 21:29:09 A2442SG MobileDeviceUpdater[12633]: Entered:_AMDFUDeviceDisconnected, libusbrestore-device:0x0x159f11fb0
May 5 21:29:09 A2442SG MobileDeviceUpdater[12633]: Entered:__thr_AMDFUDeviceDisconnected, libusbrestore-device:0x0x159f11fb0
May 5 21:29:09 A2442SG UARPUpdaterServiceDisplay[26479]: Entered:_AMDFUDeviceDisconnected, libusbrestore-device:0x0x132e19720
May 5 21:29:09 A2442SG MobileDeviceUpdater[12633]: DFU mode device disconnected
May 5 21:29:09 A2442SG UARPUpdaterServiceDisplay[26479]: Entered:__thr_AMDFUDeviceDisconnected, libusbrestore-device:0x0x132e19720
May 5 21:29:09 A2442SG UARPUpdaterServiceDisplay[26479]: DFU mode device disconnected
May 5 21:29:13 A2442SG AMPDeviceDiscoveryAgent[589]: Entered:_AMRecoveryDeviceConnected, libusbrestore-device:0x0x13290e390
May 5 21:29:13 A2442SG AMPDeviceDiscoveryAgent[589]: Entered:__thr_AMRecoveryDeviceConnected, libusbrestore-device:0x0x13290e390
May 5 21:29:13 A2442SG com.apple.configurator.xpc.DeviceService[17601]: Entered:_AMRecoveryDeviceConnected, libusbrestore-device:0x0x6000012442a0
May 5 21:29:13 A2442SG com.apple.configurator.xpc.DeviceService[17601]: Entered:__thr_AMRecoveryDeviceConnected, libusbrestore-device:0x0x6000012442a0
May 5 21:29:13 A2442SG com.apple.configurator.xpc.DeviceService[17601]: failed to get board config from recovery mode device
May 5 21:29:13 --- last message repeated 1 time ---
May 5 21:29:13 A2442SG UARPUpdaterServiceDisplay[26479]: Entered:_AMRecoveryDeviceConnected, libusbrestore-device:0x0x132f18c20
May 5 21:29:13 A2442SG UARPUpdaterServiceDisplay[26479]: Entered:__thr_AMRecoveryDeviceConnected, libusbrestore-device:0x0x132f18c20
May 5 21:29:13 A2442SG MobileDeviceUpdater[12633]: Entered:_AMRecoveryDeviceConnected, libusbrestore-device:0x0x159f11e30
May 5 21:29:13 A2442SG MobileDeviceUpdater[12633]: Entered:__thr_AMRecoveryDeviceConnected, libusbrestore-device:0x0x159f11e30
May 5 21:29:14 A2442SG com.apple.configurator.xpc.DeviceService[17601]: failed to get board config from recovery mode device
