A2179 / Board 820-01958 - liquid damage, 5v- loop 54 -0 54 ma
samstown
I got this board, water on the right side, not on CPU side, corrosion on recto/verso.
I get
PPBUS_G3H = 12.27
PP3V3_G3H_RTC = 0V
Thanks
Sam
"water on the right side"
Audio board affected by corrosion on both sides?
Also check audio flex and connectors.
Post diode mode to ground at 3V3_G3H_RTC.
samstown
Thanks. By right side, I meant on USB-C connector side. nothing on audio/jack board
Diode mode to ground at 3V3_G3H_RTC = 0.400
samstown
Thank you, was short. I don't see the value of that resistor. How can I know what resistor I can take to replace it ?
btw I've read another poste to check if T2 is still ok, R6401 (PIN1) SPKRAMP_RESET_L, diode mode to GND =0.351, that mean T2 should be ok.
"was short"
What was short?
The resistor itself MUST be short (between its pins); is 0 ohm resistor!
Do you get voltage on its both pins?
Missing enable signal.
May have a problem with U7000; try changing it.
The resistor value is marked on the schematic...
