flooding near USB-C ports J3300_CXT, cleaned!
consumption 20v /0.000 stable! no in DFU.
replaced battery with charged one! PPBUS_G3H=12.4v. need your help
Bad SSD can impede to complete DFU.
However, machine should enter DFU.
We many times seen machines solving missing SSD voltages after DFU restore.
So, working SSD is not required to enter into DFU.
Did you try external switch method to force DFU? -yes ! not working.
I examined the SSD area and found that the PP0V9_SSD0 line = 0V. and in diode mode 0.030. in resistance mode 30 megaohms. I removed the SSD but the readings did not change.
I tried everything! It doesn't work! Since I have all the power and it should work, I'm inclined to think that maybe the MacBook is in DFU but there is no signal on the USB for another Mac to recognize it! Maybe there is a problem with the Thunderbolt or something like that! I even installed another SoC and it also didn't go into DFU but it should!
If problem persists after changed T2, you may have problems with the USB-C port dedicated to DFU.
Check around U3100_X and J3300_CXT.
Something is affected by corrosion there.
May need to reball/change CD3217 chip...
