mgladin
Greetings,
I have a MacBook I am looking at that is stuck at 5v. I just had the same board in with the same issue a couple of weeks ago, so I checked around the CD3217 ICs and found a short on C3208 (PP3V3_UPC_XB_LDO), so I removed the CD3217 IC and found the short was removed. I proceeded to replace the ICs on both sides to be safe, but the issue still persists. I cannot get it to boot into DFU mode either, so not sure what I am either doing wrong or what the issue may actually end up being. Any suggestions to help me proceed forward? Thanks in advance.
Edit: I checked all lines around the IC and found that all the readings were correct.
