A2337 820-02016 no display
hgoncalves
I have an A2337 820-02016 with no internal image, and it had contact with a bit of liquid.
LP670 was burnt, and CP677 was also burnt.
After replacing them, I get 5.1V on them, but still no internal image. On external display i get image.
Already tried a good display, but same result. Can you help?
Be sure LPDP_INT_HPD has same value.
EDP_PANEL_1V8_EN present?
Also check 3V3/5V_SW_LCD.
Diode mode readings on pins 1/3 of JP600 are correct?
hgoncalves
LPDP_INT_HPD = 1.152V
EDP_PANEL_1V8_EN = 1.799V
5V_SW_LCD = 5.187V
5V_SW_LCD = 3.274V
JP600 diode readings:
1=0.351
2=0.604
3=0.350
