A2338 820-02020-11 no power
hgoncalves
I have an A2338 820-02020-11 that had liquid contact, and has no power.
Om ampmetter it puls 5.16V and 0A.
I supose that I should start to check CC1/2 on CD3217, but I realy don't know where to start. Am I right? If any is damaged, can I replace it with one of other model board? JT700 is burnt. Can I replace it with one of other board model (don't have any board of this model)?
If you get 5V from charger, CC1/2 lines should be good.
The board is probably trash, after liquid damage.
You can check diode mode to ground on the coils, at least.
hgoncalves
No big coil seams to be shorted. Diode reading seams normal.
However LT700 is burnt, and PPVOUT_LCDBKLT is shorted
hgoncalves
I managed to power it on. It had the PPDCIN_USBC_AON area oxidated and after replacing some caps and cleaning it, now powers on again and boots to OS. However T2174 is missing. Should I jumper it?
Can I take the burnt JT700 and LT700 from other board model?
Be sure the trace of T2174 is not broken; in case the TP is in the middle.
You can take L/JT700 from different board, no problem.
