A2338 - 820-02773 No power. Stuck on 5V.
ronaldo
Hi, everyone.
I need some help, please.
This Macbook came in with no power. After inspection I found
Liquid damage, corrosion near USB C controller (CF300)
Both ports were initially stuck on 5V
Replaced the USB C controller that is stuck on 5V, no difference.
Replaced the second USB-C controller, no difference
ISL9240 was replaced and is still the same.
Both USB-C ports are stuck on 5V and 0.3amp for 3 sec and drop to 0.02amp.
Measurements around controllers match with a good board.
I can't think of the next step. Please help.
I did replace from a M1 pro board and now one port is getting 20V and cycling and the other one is still stuck on 5V.
So you've replaced both chips from donor board same model, maintaining their position on the MLB?
Usually cycling port is trying to boot, so problem should be on the other port.
