I've got a MacBook that had liquid damage/corrosion only limited to the EDP connector for the LCD. The corrosion was only on the TCON board (I think it's called that) and the cable. The connector on the logic board side was not damaged. I replaced the flex cable and EDP connector on the TCON board. I still have no image/backlight.
The computer boots and has external display output.
I noticed that all my diode mode readings along the bottom pins of the connector on the TCON board return O.L.
I have a feeling a known-good LCD will be advised to test. But is there anything else I can check?
Also does this screen replacement require chip swap/angle sensor calibration or can I just swap the entire assembly?
Thanks!
Thanks!
