A2442 02098
Liquid damage, data recovery is a priority
Lots of damage everywhere, I replaced and reworked 70-80% of stuff that I thought is critical
When I start diagnostics - 5V 0amp on cable, out of the chasis
After PMIC U8100 replacement I'm getting 5V 0.25-0.3 amp
Nothing is getting warm, I didn't discover any shorts
Whats giving me a head ache is the U8100
Pulled it from my own 100% working A2442
So:
- logiwiki says it should turn on bucks if PMU_VDDHI ~4.7
I was getting 3.2 ish
- outputs of U8100 are unstable
- schematics says both resistors there should be 200k
- one resistor(R8170) from the damaged board was corroded, so I assume it's out of spec(?)
- To limit potential errors I pull both from previously mentioned known good board
- I check both of them, one is 290k, other is 1.07M
Schematics says both 200k
I check with online voltage divider calcs, 2 different combinations of this give either 10V or 2.6V
Is it my lack of knowledge or the information is wrong somewhere?
When I removed both, on cable 5V, 0amps of course - so perhaps I looking at the right place?
But I need help - I'm not able to fully understand how the U8100 works.
And if I'm missing power on signal or something like that?
PP1V8_S2 unstable 0-1.8
PP5V_S2_MAIN unstable 5.2-0
PP1V2_AON stable 1.199-1.2
PP1V2_S2 unstable 0-1.2
P5VS2_TPS_PWR_EN unstable, on/off - from what I understand this is turning on UC260 which produces PP5VS2_MAIN
PP3v8_AON 3.8 stable
PPDCIN_AON 5.155-5.148
PPBUS_AON 12.30-12.29
So:
