A2442 - 820-02098A 5V 3mA-0mA
jadao
Got this board for repair, 5V 3mA for a couple of seconds then 5V 0mA. it had a tiny spot of liquid damage on C7768 (PP1V2_AON_SPMU pad corroded gone ) and C7780 (PP1V5_AON_VCORE_SPMU pad corroded gone).
PPBUS_AON: 12.29v
PP3V8_AON: 3.8v
PP3V8_AON_MPMU_ISNS: 3.8v
PP1V2_S2: 0V / 0.231
PP3V3_S2: Unstable 3.3V to 1.25V / diode mode value: 0.376
PP1V8_S2SW_CLVR_VDDC1_LDO: Unstable 1.8V to 0.5V / diode mode value: 0.492
PP3V3_AON: Unstable 3.3 to 0V / diode mode value: 0.375
PP0V8_S2_CLVR_VDDDIG: Unstable 0.8V / diode mode value 0.289
PP1V8_AON: 1.8V
PP1V2_AON: 1.2V
PP1V5_AON_VCORE_MPMU: 1.5V
PMU_VDDHI: 2.584V
I replaced U8100 from same donnour board and I got exactly same results...
I compared coils diode value around U8100 and U7700 with donnour board and they are the same. I also see no voltage on any coil around u7700.
Damage affected 2 signals PP1V2_AON_SPMU and PP1V5_AON_VCORE_SPMU coming right from U7700, but I have no way to test them for shorts because pads are gone on the filter capacitors...
You are right, despite liquid damage was exactly on the other side of SPMU board, I thought PP3V_AON unstable must have to do with (mpmu) U8100. I should have asked before.
Now I am exactly at square one, I was going to replace spmu but wanted to ask if any other conditions to check before reballing a replacement one…
Thks
Voltage / Diode mode value
I have exactly same reading before and after replacing U8100.
Thanks
U8100 LDOS:
VIN_LDO1=VIN_LDO2=VIN_LDO4=VIN_LDO1V8=VIN_LDO1V2=VIN_VCORE=PP3V8_AON_MPMU_ISNS: 12.29V / 0.174
VIN_LDO5=PP1V2_S2: unstable 0-0.4V / 0.231
VLDO1 : PP3V3_S2: Unstable 3.3V to 1.25V / 0.376
VLDO2 : PP1V8_S2SW_CLVR_VDDC1_LDO: Unstable 1.8V to 0.5V / 0.492
VLDO4 : PP3V3_AON: Unstable 3.3 to 0V / 0.375
VLDO5 : PP0V8_S2_CLVR_VDDDIG: Unstable 0.8V / 0.289
VLDO1V8 : PP1V8_AON: 1.8V / 0.426
VLDO1V2 : PP1V2_AON: 1.2V/ 0.592
VCORE: PP1V5_AON_VCORE_MPMU: 1.5V / 0.368
U7700 LDOS:
VIN_LDO0=PP1V2_S2 : unstable 0-0.4V / 0.234
VIN_LDO3=PP1V8_S2 : 0V / 0.235
VIN_LDO1V8=VIN_LDO1V2=VIN_VCORE=PP3V8_AON_SPMU_ISNS : 3.8V / 0.174
VLDO0 : PP0V72_S2_VDDLOW: 0V / 0.239
VLDO3 : PP1V2_AWAKESW_BLC: 0V / 0.669
VLDO1V8 : PP1V8_AON_SPMU: 1.8V / 0.516
VLDO1V2 : PP1V2_AON_SPMU: can't measure, no more pad under the cap.
VCORE: PP1V5_AON_VCORE_SPMU: 1.5V / 0.385
U8100 BUCKS:
BUCK0 PPVDD_ECPU_AWAKE L8200@L8203 : 0V / 0.116
BUCK1 PPVDD_GPU_BMPR_S1 L8210@L8211 : 0V / 0.253
BUCK2 PPVDD_ECPU_SRAM_AWAKE L8220 : 0V / 0.378
BUCK3 PP1V8_S2SW L8230 : unstable 0-0.08V / 0.289
BUCK4 PPVDD2H1_S2SW L8240@L8243 : unstable 0-0.4V / 0.062
BUCK5 PPVDD_AVEMSR_AWAKESW L8250@L8253 : 0V / 0.125
BUCK6 PPVDD_AMPH1_S2SW L8260: unstable 0-0.4V /0.400
BUCK7 PP0V81_S1_SRAM L8270@L8272: 0V / 0.180
BUCK8 PP1V2_S2 L8280: unstable 0-0.4V / 0.234
BUCK9 PPVDD_FIXED_S1 L8290 : 0V / 0.181
BUCK10 PP0V575_S1_VDDQ1 L82A0@L82A1 : 0V / 0.116
U7700 BUCKS:
BUCK11 PPVDD_SOC_S1 L7850@L7853 : 0V / 0.030
BUCK12 PP1V2_AWAKE L7880 : 0V / 0.223
BUCK13 PP0V575_S1_VDDQ0 L7810@L7811 : 0V / 0.113
BUCK14 PPVDD2H0_S2SW l7840@L7843 : 0V / 0.063
BUCK16 PP0V855_S2SW_VDDCIO L7860: 0V / 0.180
BUCK17 PPVDD_DCS_S1 L7800@L7803: 0V / 0.135
BUCK18 PP0V95_S2SW_VDD2L L7820: 0V / 0.312
BUCK19 PP1V8_S2 L7830: 0V / 0.230
BUCK20 PPVDD_DISP_AWAKESW L78A0@L78A2 : 0V / 0.044
BUCK21 PPVDD_AMPH0_S2SW L7890 : 0V / 0.398
All values compare ok with openboard except the 3 listed here but they are good compared to known working board.
To me they all looks good.
U7700 BUCKS:
BUCK11 PPVDD_SOC_S1 L7850@L7853 : 0V / 0.030 -> on good board 0.040 -> openboardData 0.130
BUCK17 PPVDD_DCS_S1 L7800@L7803: 0V / 0.135 -> on good board 0.110 -> openboardData 0.231
BUCK20 PPVDD_DISP_AWAKESW L78A0@L78A2 : 0V / 0.044 -> on good board 0.056 -> openboardData 0.199
The two capacitors mentioned in first post, are used for the stability on their rails.
U7700 may not work properly if these voltages are not correct.
