A2780 - 820-02890 - no picture - no chime
maxwell
Hi!
I have a MacBook Pro 16" A2780 (820-02890) on my desk and am stuck. Here are all my observations and measurements so far:
1. Symptoms & Behavior with the Trackpad Cable
- With the original trackpad cable: When plugging in the charger and powering on, the fans immediately ramp up to 100% full speed, with no image and no startup chime.
- With a new replacement cable: The fans stay completely off (0 RPM), still no image and no chime.
2. USB-C Power Meter & Power Button Behavior
- With battery connected: Voltage negotiates to 20V, current starts at 2.0A and gradually drops to 1 A. When the battery was empty the current was way higher.
- Without battery: Current stays constant at around 0.02A.
- Power button sequence (with battery connected):
1. Long press (~10 sec): The USB-C meter reboots and reconnects (hard reset).
2. First short press afterward: The USB-C meter briefly reboots again (likely when the USB controllers initialize).
3. Subsequent short presses do nothing until another 10-second long press is performed.
3. Tests Performed So Far
- The M2 SoC gets warm to the touch after the short power-on press.
- No external video output via HDMI.
- Caps Lock LED does not light up
- Connecting the rear-left USB-C port (next to MagSafe) to a Windows PC shows no USB/DFU device recognition in its current state.
4. Measured Voltages & Resistances (after power-on press)
All Always-On, NAND, and ECPU rails come up:
- P3V8AON_VSW1 = 3.8V
- P3V8AON_SW2 = 3.8V
- P3V8AON_SW3 = 3.8V
- P1V8VDDH_SW1 through SW5 = 1.8V each
- P2V5_NAND0 = 2.57V
- P1V2_NAND0 = 1.23V
- P0V9_NAND0 = 0.84V
- PPVDD_SOC_1 = 0.644V
- PPVDD_ECPU_AWAKESW = 0.85V
- PPVDD_ECPU_SRAM_AWAKESW = 0.91V
- PPLUXE_LX1 = 0.2V (resistance to ground measured without power and connected display: about 8 kOhm)
What could be the issue?
I am a bit lost here.
