A2992 820-02918 (14" M3 Max) – no image, mini-LED zones still track content – after drop
devoniodd
Machine: MacBook Pro 14" M3 Max, A2992 / Mac15,10, board 820-02918, macOS 26.6.2.
History: low drop. Worked normally for ~1 day, then intermittent (one reboot brought it back), now permanent, also after 30 min powered off.
Symptom: no image on the internal panel. Mini-LED local dimming still works: zones light up following the content, so I see a very low-res blurry glow of the desktop. Brightness keys change it. External display perfect, screenshots correct.
Done so far:
  • Lid angle / pressing the bezel: no change
  • Reseated eDP and backlight flexes: no change
  • 3.8 V panel rail present at the MLB eDP connector (unloaded, flex disconnected); no short to ground on the display side.
  • Logs: no DCP/IOMFB errors or panics, DCP power state normal, brightness commanded normally. Only change: IOMFB: panel charge parity violation value jumped ~100× at fault onset (0x3F9D60 → 0xF9xxxxx) and stays there
  • IORegistry names the panel chain AppleParadeDP835TCONI2CTps65177
  • Heat on lower bezel: no change
My reading: the eDP link and TCON are alive (backlight only enables once video is stable), so the fault is downstream: LCD bias rails, gate/source drive, COF bond or glass.
Questions:
  1. Has anyone measured the LCD bias rails (AVDD/VGH/VGL/VCOM) on the panel-side TCON board of A2442/A2779/A2918/A2992? Test points or typical values?
  2. Is the bias IC really a TPS65177 (Vin 8.6–14.7 V per datasheet)? With a 3.8 V panel rail there must be a pre-boost. Which part?
  3. Can the TCON board be reached by removing only the bottom bezel, or does the LCD bottom edge have to be lifted?
  4. Does anyone know what “panel charge parity violation” counts?
