Air A2179 820-01958-A
lincev
Hello, I need help with this board. It worked correctly but my brother forgot the charger. I tried to connect it to a hotel USB port to charge it and it didn't turn on again.
I have checked it under a microscope but I don't see any burned or damaged components with the naked eye. With another laptop if the apple configurator detects the presence of this board.
thanks to all
lincev
omg! sorry
values only with charger (without battery):
PP3V3_G3H - 2,96v
PP5V_G3S - 5v
PPVIN_G3H_P5VG3S - 12,5v
PPVIN_G3H_P3V3G3H - 12,5v
PPBUS_G3H - 12,5v
PPBUS_HS_CPU - 12,5v
"PP3V3_G3H - 2,96v"
Which pin of L7690?
Did you check diode mode ground too?
Is the machine recognized into DFU mode?
lincev
L7690 pin1 3,26v
mode ground any short´s at PP3V3_G3H, PP5V_G3S, etc..
The Apple configurator detects the board in lock mode (locking logo) but cannot put it in DFU mode.
So 3V3_G3H is correct.
Remember to always check voltage on the output pin of a coil from any buck-converter!
Try to force the machine in DFU with wire method.
lincev
ok try this, sorry I can't see ur answer.
I wanted to try to recover the information but I see that there is no solution
thx to all
lincev
Good morning, macbook in dfu mode restore load operating system and halfway (approximately) restart and cancel then I can see logo "padlock"
I try this 3 times and 2 cables usb-c genuine
cpu dead?
