Apple MacBook Pro A2141 / 820-01700 / Water Damage
zeydullak
Hi guys,
We have Apple MacBook pro A2141 that has water damage. We removed the Logic Board from the laptop. USB-C meter showed the volt switches to from 5 to 20 volt. Ampere is goes 0.05 ~ 0.09 ~ 0.25 then backs to 0.04 amp. We inspected the logic board and found water mark and corrosion. I attached the photo of logic board and pointed out the place the corrosion was. We cleaned the logic board by washing it under DI water and it is very clean like brand new. We checked amp and volt again. The amps goes to 0.35 and goes back to 0 like a loop. The voltage is 20v.
I need your help in this situation to move forward and to troubleshoot the issue. Please advise what to check. Thank you. See attachments as well
Diode mode testing results:
L9080 - 0.2250 vdc
L9580 - 0.3000 vdc
L3500 - open
L7700 - 0.2431 vdc
LB700 - 0.2214 vdc
LB150 - 0.2902 vdc
L9521 - 0.3357 vdc
L9520 - 0.3400 vdc
L9530 - 0.3620 vdc
L8410 - 0.8567 vdc
L6960 - 0.4036 vdc
L6961 - 0.4036 vdc
L7660 - 0.3650 vdc
L9030 - 0.4136 vdc
L9020 - 0.4600 vdc
Is the machine recognized in DFU mode?
BTW, don't bother to write "vdc" for diode mode readings.
Avoid any confusion with voltage readings.
