Apple MacBook Pro / Model A2141 / Board # 820-02037-06 / Water Damage /
zeydullak
Hello,
We have Apple MacBook Pro that had corrosion on certain part of it. We washed it and clean using DI water and it is clean now. The laptop uses 20v, charges well 3amps usage. Caps Lock has activity, USB flash drive conenctivity is there. We dont have a graphic output. Even used external monitor but still no picture. We can get to DFU mode and we get out of DFU mode without any problem. We need to get the data from this MacBook. Can you please advise what can we do here?
Regards,
Zeydulla.
Did you test external video disconnecting internal LCD?
"We can get to DFU mode and we get out of DFU mode without any problem"
I hope no DFU restore has been done; SSD gets erased in such case.
If data is still there, it can be recovered in DFU mode, by an Apple authorized service.
If finally no video at all (internal & external), try to put the machine in target disk mode.
