CD3217B12
Kappy
Are CD3217B12 firmware protected? I tried searching the forum for the answer to this question.
I have an A1932 board and tried what I thought 3 x CD3217B12 which have come from various board in the past (not sure which model) and none of them are behaving properly.
Also I've a stencil for this component but i'm not sure if it's producing the correct size solder balls. Written on the stencil is 0.12mm but after watching a few You Tube clips I've notice people are using 0.3mm balls. Which is correct?.
CD3217 has firmware, as CD3215 for sure.
Termination code specifies the firmware, so you must use the same full code chip.
Using solder paste you should get good balls in the stencil.
