GPU Imac 27 2009-2011
You should not do that as it will cause temp/current sensor issues. When an unsupported card is installed it will give image and seem to work fine but there will be no thermal control and the card will slowly cook itself.
Why do you want to swap video cards anyway?
Yordanov
Because some are faulty and need to take good cards from faulty motherboards to assembly full working iMac. So, no solution?
Depending on which GPU is in there some cards can be fixed if chips are available. 6970m is hopeless and 4850m too. Which ones do you have?
Yordanov
I got one new GFX card from Apple 512MB. It has 216-0810005 chip there. I can use it only for 2011? Or I can use it for 2009-2011
