[HELP]A1466 820-00165 ULTRA SLOW!
phantom
hi! i've received a a1466 completely dead.
i've found water around u6101 and u1900
removed ics cleaned and soldered two other ic from donor board! all ok!
today i 've received again this laptop...dead...again
i've used some solder and flux on u6101 and again live!
BUT...
it is extremely slow i have to wait like 30 secondo to hear the sound and 10 second to see the logo since i push the power button
then system bar start to load but OS seems impossible to charge...
if i use another ssd, it boot faster...and i can use the laptop without problem.
only problem is that cpu seems extremely hot even if i have changed the thermal paste
now i have tried to format the original ssd...but it is loading catalina from usb since like an hour!!!!
diagnostic test doesn't find anything...only "poor battery performance"
Still works good with other SSD?
If yes, install HWMonitor there and check components temperature and I/V sensors.
phantom
Hi! Thank you for your reply! With original ssd is even impossible to fully load an operating ststem to install from usb
With my Ssd no problem at all!
So i think problem is fixed…even if cpu is very hot..
But macs fan speed doesn’t find any problem!
Ps please help me with my other thread!
Is a lot more important! Thansk
phantom
problem not solved: today i've powered on the notebook....and it hangs at the end of the loading bar....with my ssd :(
phantom
can you help me to find a clean me bios???
what do you mean with usb macos? you mean with an os INSTALLED ON USB?
phantom
so, with an external ssd, it charges the loading bar in eternity....i'm still waiting to see the login screen
and still cpu super hot with fan that should spin super fast (because of cpu super hot), but it spins normal
with internal ssd, it boot to login screen but it stuck here
cpu super hot...
phantom
BUT...
No errors in diagnostic test
Check all U6101 traces.
Also check all SPI Bus Series Termination resistors and traces.
Clean/remove J6100, if affected by corrosion.
