Help with A1990 / 820-01041
The first step with T2 machines, is trying DFU.
If machine is not recognized, then need to dig in hardware.
Follow the DFU tutorial linked in the forum:
No battery needed for DFU.
USB-C charger will stay in 5V all the process.
Write directly into reply box, instead of clicking Reply button.
Unless you have any reason to quote an entire text, visible few centimeters above.
Please, maintain forum aesthetic...
j07rdi
So I plugged a genuine USB-C Thunderbolt into the left/front USB and attached it to another MacBook pro with Apple Configurator 2. No luck.
"Write directly into reply box, instead of clicking Reply button."
This avoid the quote.
Check if all AWAKE and SLPS2R voltages are present; small coils surrounding U7800.
j07rdi
Hello, fixed the formatting of my comments. Here are the powers measured:
PP1V2_AWAKE = 0V
PP1V2_AWAKE_SOC_PCIEPLL_F = 0.03V Flickering
PP1V2_AWAKE_SOC_PCIEREFBUF_F = 0.04V Flickering
PP1V2_AWAKE_SOC_PLLCPU_F = 0.04V Flickers
PP1V2_AWAKE_SOC_PLLSOC_F = 0.04V Flickers
PP1V8_AWAKE = 0V
PP1V8_AWAKE_SOC_FMON_RC = 0V
PP1V8_AWAKE_SOC_TSADC_RC = 0V
PP3V3_AWAKE = 0V
PPVDDCPUSRAM_AWAKE = 0.2V Flickering
PPVDDCPU_AWAKE = 0V
PVDDCPUAWAKE_FB = 0V
PVDDCPUAWAKE_FB_R = 0V
PVDDCPUAWAKE_SW0 = 0V
PVDDCPUAWAKE_SW1 = 0V
PVDDCPUAWAKE_SW2 = 0V
PVDDCPUAWAKE_SW3 = 0V
PVDDCPUSRAMAWAKE_FB = 0V
PVDDCPUSRAMAWAKE_SW0 = 0V
SOC_BLUE_AWAKE = 0V (components around not populated).
PP1V8_SLPS2R = .2V Flickering
PP1V8_SLPS2R_PMUVDDGPIO = 0V
PP1V8_SLPS2RSW_DFR = 0V
PP1V8_SLPS2R_SOC_LPADC_RC = 0V
PP1V8_SLPS2R_SOC_LPOSC_RC = 0V
PP0V8_SLPS2R = 0V
PP1V1_SLPS2R = 0V
PP1V25_SLPS2R_SMC_AVREF = 0.2V Flickers
P1V1SLPS2R_FB = 0V
P1V1SLPS2R_SWO = 0V
P1V1SLPS2R_SW1 = 0V
No need to check all, if you find at least one missing.
Possibly bad U7800, if you get short to ground on several of its coils.
j07rdi
Hello,
So I sourced it, and I was able to successfully rework the U7800, but it didn't work. Exactly the same behavior.
j07rdi
Yes, I did. It is not exactly short, it is around 3-5 ohms. I did apply low voltage and the current was around 3-5A in some areas, and they are in agreement with the max amperage defined on the schematic.
j07rdi
So I'm fried then. Well, I have a motherboard with 1TB and 32Ram that could be used for parts. I also have an intact shell, LCD, and all the tiny pieces. Is anyone interested?
