help with an acer la-j871p
i am new to repairing non-apple motherboards. this boards has a problem with +3valp. I was getting a low resistance to ground on the rail and i injected 1v. the pch got warm so removed it. the short seemed to be gone but +3valp is still missing. i'm getting 5v on +5valp. DB1 is two pin diode that send the enabled signal. it has mainpwon at 3.3v on one side and 3v_en is 0v on the other side
I supposse 3V_EN_R is missing.
KBC may be damaged too, or needs reflash.
Check first if all its required signals and power are good.
This signal comes out from KBC, not PCH.
3V3 controller powers both of them and KBC may also be affected; in case of overspike.
Read again my previous post...
