So, I got a 820-00597 logic board to replace the one in a 2017 21.5 4K iMac. It worked fine when I got it, powered up fine, was able to install MacOS on it. All done on the bench of course. I decided before putting it in the chassis to reapply the thermal paste for the CPU and GPU and look over the board to make sure there weren't any issues. I noticed a cap had been pulled up off the board (still attached on one side) and soldered it back in place. It was part of the Ethernet circuit, I can look up the specific one if it's important. I also decided to swap the EFI rom chip from the original board so the serial number would match. I had done it several times before on other boards with no issues. After these several steps, I put everything back together and the logic board won't power on. It draws ~ 0.1Amps when power is applied, drops to 0.08 amps then stays there. Strange thing is, if I short the power pads the logic board will act like it is powering off, dropping to 0.03 amps drawn. If I then short the power pads it will go back up to 0.1 amps and do the same thing again. I checked that PPBUS_G3H is being generated. Also diagnostic LED 1 stays solid, it doesn't flicker. None of the other LEDs come on. Anyway, just wanted to see if anyone had any idea what might have happened to it. I wanted to get this board working again because it's got the Radeon 560 4GB graphics.
