Imac 27 2013 PA-1311-2A1 shorted
mobajer
I have found short on red marked diode.The diode is good, there are no shorts on caps, transistors, diodes. is there schematics for that power supply?
any advices?
Inwerp
this should help:
https://www.youtube.com/watch?v=pffOJdCQ7kw&t=67s
it looks like a part of the rectifier circuit. i would start with the transistor, however, there's no info - do you have a short circuit on your mains?
honestly, if you had a short in this area, you would not have any doubt about that - this is a high voltage area, any short here blows fuse or smokes pretty bad.
Probably because it is across a coil. Fixing these PSUs is a complete waste of time as failures are very often catastrophic and multiple parts and chips have burned out. Don't waste time on these unless it is a simple failure like a popped fuse because of a shorted rectifier or main cap.
