MeTech Turkey
Hello everyone,
First time I have tried to upgrade my iMac ram storage from 8GB to 16GB. Let me tell you the story first.
It had 4 of HYNIX H9CCNNNBLTBL-ARNUD ram (each 2gb) totally 8GB. Then we started to search and found out that my computer is compatible with 16GB of ram too.
Then we have found another 4 ram chips which makes totally 16GB with the code of ELPIDA FA232A2MA-JD-F. Then we have applied the ram configuration on schematic as you can see attached photos.
1) Removed the R1687 and put 100K resistor to R1683 on RAMCFG0
2) Removed the R1686 and put 100K resistor to R1682 on RAMCFG1
3) Removed the R1685 and put 100K resistor to R1681 on RAMCFG2
4) Kept R1684 on its place on RAMCFg3
5) Removed the R1689 and put 100K resistor to R1688 on RAMCFG4
But after I did this configuration the device stays on black screen, I can hear that HDD works, fan spins, no beeps from speaker and the LED lights on the mainboard
LE0301 (ITS_PLUGGED_IN), LE0302 (CORE_VOLTAGES_ON_R, CORE_VOLTAGES_ON) but LE0303 (MEMORY_GOOD_R, MEMORY_GOOD) LEDs do not light on. I have waited nearly a minute but nothing changed.
I have checked with thermal camera after plugged in and also press the power button nothing seems short.
Any suggestions or advices you can give me to check because I was struggled with understanding this ram configuration thing? I do still think that I did something wrong there or rams from another mainboard are not working. And is there anyway I can understand if the rams are working or not?
Thank you
Emre
Thank you
Emre
