Hi
I have got Ipad 8th gen for charging issue it has been with other shop for the same fault,
It wasnt coming on or taking any charge at all before but after diagnosing found out the Resistor R3533 was blown so after replaced resistor R3533 it is taking some power which is 0.46amps but not around 2amps and also comes on but NOT CHARGING on battery sign.
could you help me out with this problem.
Tristar is replaced U3500
charging flex replaced twice
Q1704 and Q1705 replaced as well because previous work been done to it
U3300 is replaced as well.
U1707 is changed too
all of them ics and flex replaced as previous shop tempered with it.
