iPhone 5 PP_VCC_MAIN SHORT TO GND
VirtualLife
I have water damaged iPhone 5 that has short to ground in PP_VCC_MAIN line.
Here a photos where water damage was and i cleaned it with ultrasonic cleaner and removed some of them that was really bad but nothing helped.
The red squares are the were water damage was.
Where should i check?
aprendiz
Moderator
4V 2Amp is enough..... if you cant detect heat with this, you can go up in amps no in voltage and go slowly up....
