Is it possible to fix a missing pad to place pin on motherboard LCD
99% of the cases you can run a strand of wire to the component the pad used to go to. Depends on which pin got ripped.
You can see the via that the trace is running to. Just solder a strand of wire to the via and then to the connector pin.
No Title
Do you mean lkike this, Blue line.. Check phot.. From pad to this little circle??
