wrbailey
2012 13" Liquid damaged Air 820-3209-A
Has an image. No backlight. Went over Rossmann's no backlight sticky...
I have 8.4 volts at left side of L9701 and 0.033V on the boosting side.
I did have an F'd up LED driver. Half the pad was still there, but the connection between the pad and the trace was gone. I ran a TINY jumper to the pad and it looks perfect.
Still turns on and no backlight. I checked for continuity on all the broken trace suggestions in the sticky and I don't know where to go from here.
R9731 is fine and I do get 2.9v at BKL_EN.
Backlight fuse is fine (unfortunately)
Connector doesn't look damaged at all, and I've tried known (cracked) good working LCDs (at least my backlight test screens.)
I have 5v at PP5V_S0 and 3.3v to the LED Drvr
any help? I tried two different LED drivers due to swapping out to a smaller jumper to FB ball. No change.
