Liquid-damage A3114 M3 Air with CPU throttling (820-03286)
sekidata
This A3114 15" Air came in with liquid damage, mostly in the trackpad circuitry area. The damage was repaired and trackpad functionality was restored.
The machine acts completely normal except for a much lower than expected CPU speed. Using Cinebench, the machine’s CPU ranking is 1201, compared with the expected 8000. It passes Apple Diagnostics and shows no errors.
Any suggestions for troubleshooting the throttled performance?
sekidata
Yes, only the logic board was affected. Trackpad & cable are known good parts, tested on another machine.
sekidata
Apparently, the CPU reports that its base frequency is 0.7-0.9 GHz. Way too low.
Some SSD components are close to trackpad area; may be also affected.
Trackpad includes some temperature sensors.
Completely changing trackpad board and flex should discard such an issue.
Check all pins and traces for trackpad connector.
sekidata
The SSD shows the expected read/write speeds, so I don't think it's affected.
I tried two different trackpads with no change. When I unplug the trackpad, there is no change either.
I assume the sensor data is sent over the same SPI bus as tracking data?
sekidata
I replaced the I2C bus level shifter UD230 just in case, but no change and all looks good here.
Is there a good way (software?) to check which sensor is misbehaving and causing CPU throttling?
