M1 MacBook Pro stuck on "Continue Holding for Startup Options"
JustinJo
This machine came in and it WOULD boot to the lock screen, but no KB or TP. I did a liquid damage repair and cleaned some minor spots on the board and replaced the trackpad. Now its stuck on "Continue Holding for Startup Options."
If I select the hard drive from the menu, it looks like its gonna boot the OS, then it restarts.
I can go into options and Run First Aid on the disk, the disk has some warnings, then says its fine. Same result.
Safe Mode same result
Diagnostics, same result. - Just restarts.
Power button has not effect when the laptop is powered on.
I get same result with power button disconnected.
Tell us which components and traces have been affected by liquid damge.
What is the exact 820-0xxxx code of your board?
Is the SSD data important?
