Macbook 820-00165- Only Fan Spin
Instafixx
Only FAN Spin.
PPBUS is 8.6V
PP3v43 is 3.4V.
No Corrosion or dirt.
Drawing around 600 amps.
Fan Spins and the gradually goes to max in 10-15 seconds.
That behavior is normal if no trackpad connected; when testing the board alone on the desk.
Another thermal sensor can also cause this symptom.
Any history available?
Do you get CPU core voltage?
PLT_RESET_L goes high?
Did you check USB activity?
CPU core voltage; the big two coils near CPU.
No matters, if PLT_RESET_L goes high, power sequence is completed.
Tried known good BIOS?
