Macbook 820-00239 SSD
Instafixx
Display Flex is ripped off. ( FlexGate )
Question Mark Folder Flashing.
Just connected the board on table to a external monitor to rule keypad and any other flex shorting.
R9350 PICCOLO_IUVD is 1.8V
Instafixx
If try going into recovery (CMD + R) it shows an error -2100F.
If i use an external drive to Flash the OS (Using the Option Button) it shows computer restarted because of an error and then just the Apple Logo and the loading bar and it gets stuck there.
Does it enter target disk mode?
Check J9600's signals and voltages.
Be sure to have good contacts left/right.
Instafixx
37-45 / 38-46 is 0.4Ohms
35/36 is 1.8 Ohms
31/32 , 29/30 , 25/26 , 23/24 , 19/20 , 17/18 Couldn't find test points.
13/14 is 3.4 Ohms
11/12 is 3.2 Ohms
7/8 is 1.5Ohms
5/6 is 1.3 Ohms
3/4 is 1.8 Ohms
1/2is 0.8 Ohms
43/44 os 0.5 Ohms
"PP3V3_S5_SSD_LB IS 0.7V
PP3V3_S5 IS 3.3V
37-45 / 38-46 is 0.4Ohms"
All these readings can't be true at same time...
Instafixx
If i Disconnect the J9600 connector and measure
37-45/38-46 is 2.8 M Ohms and reducing
PP3V3_S5 is 3.3V
PP3V3_S5_SSD_LB is 0.7V
If the connector is connected
37-45/38-46 is 1.2 Ohms
PP3V3_S5 is 3.3V
PP3V3_S5_SSD_LB is 3.3V
You don't need to make any test with J9600 disconnected.
Post voltage for pins 2, 4, 6, 8, 12, 36, 44.
As always, find proper test points; look near U9013 area.
Instafixx
Ya that is where i checking
Pin 2 = 5v
Pin 4 = 1.78v
Pin 6 = 0v
Pin 8 = 3.3v
Pin 12 = 3.3V
Pin 36 = 3.3V
Pin 44 = 13V
