Macbook 820-00426 no keyboard
No-Clean
Clean board, tested with known good keyboard and the entire keyboard doesn't work.
FPC looks good, J4813 pin 4 3V42 and pin 30 PP3V3_S4 are both fine, U4830 area looks good.
Did you try known good trackpad flex/board?
Be aware of chinese flex; I changed 3 to fix such problem one time.
Still the same problem?
KB doesn't work in boot menu, nor macOS?
Inspect U4820/30 adjacent resistors, traces and solders.
Check voltage and diode mode to ground on their SCL/SDA lines.
Just in case, check SMC_LID.
Be sure J4801 is good.
No-Clean
U4820/30 adjacent resistors, traces and solders good, SCL/SDA lines voltage 3.3V diode OK compared to working board
SMC_LID 3.3V
J4801 looks like new
