Instafixx
Device came in with no backlight. Some corrosion under UP800. Cleaned and reballed the same ic and it started working.
it worked for 10 days but again backlight gone. I replaced the ic but when I am replacing the ic the bird gets stuck at 5v. the ic is fine as installed that chip on another machine with no backlight issue and it is working.
What can be the issue here ?
