Macbook A1398 820-00138
Instafixx
L7095 Diode Mode to Ground is .330
U7090
Pin1 1.2V
Pin2 2.5V
Pin3 4.9V
Pin4 2.25V
Pin6 16.2V
Pin8 16.2V
Replace C7094 and test again.
Also removing C7095.
Check proper (ohm) value of R7095/6/7.
Playing with their values, you can adjust output voltage; as per bottom formula.
Instafixx
Replaced C7094 and Removed C7095.
Now PPBUs is 12.5V
PP3v42_g3h is 3.38V
Get Magsafe Light. No Fan Spin But.
Doesnt Boot. I get Trackpad Click.
Post PM_BATLOW_L, PCH_DSWVRMEN, PM_DSW_PWRGD, SMC_ADAPTER_EN and the 4 RTC signals.
Be sure to use 85W Magsafe 2 charger!
